05-14-2003 11:04 PM - edited 03-12-2019 11:53 PM
I have 2950 switches with one data vlan 20 and one voice vlan 200. Data is on 192.168.20.0/24 and non-cisco IP phones on
192.168.200.0/24 subnets. The 6509 is a doing an InterVlan routing.
Some of the phones will have PC connected to it and some won't. For minimizing adminstrative issues, I have enable all ports in this
fashion to carry both voice and data VLANS. Is it the write approach?
For example, Port 1 48 on 2950 have this configuration,
int fastethernet 0/1
switchport mode access ---> making port an access port
switchport access vlan 10 ---> assign port to data vlan 10 and carry data traffic
switchport voice vlan 200 ----> to carry voice traffic
switchport priority extend cos 5 -----> prioritize voice traffic
Please tell me if this is the right approach to efficiently carry both voice/data traffic. Voice with high priority.
Am I gonna need any QOS service configured on 6500 switch?
05-16-2003 12:45 AM
You did the wrong configuration for carring voice an data on different vlan.
It should be like that:
switchport mode trunk ---> making a trunk connection
switchport trun encapsulation dot1q ---> dot1q trunk between phone an switch
swithcport trunk native vlan 20 ----> to specify the data vlan for PC connected to the IP phone
Management vlan is still vlan1.
Best regards,
Aleksander Kocelj
05-16-2003 10:28 AM
Thanks ! I will make the change as you mentioned. I tested by plugging my PC to the Phone, and Phone to the Switch, and I am able to route both data and traffic with my configuration. Was it not supposed to work it all the way I did it?
2) Do I need to do any QOS on my 6509 switch as well?
Please shed some lights.
05-24-2003 08:00 AM
Yep. You do need it everywhere on your voip network.
One more remark about your config:
This command does not change voice prio. It sets the DATA traffic of a PC attached to the phone-switchport to COS 5.
Set this value to 0 or to trust. What you do with cos 5 is giving data traffic the same cos as voice traffic!!!!!
09-25-2004 06:36 AM
You don't actually need all the Trunking configuration on the switchports - it will work without it:
Interface FastEthernet0/1
switchport access vlan 20
mls qos trust cos/dscp
This configuration makes the port a 'psuedo trunk' it is the equivilent of the config:
switchport native vlan 20
switchport trunk allowed vlan 20,200
With the 2950 you can only trust DSCP if you run the EI image, also the 2950 can only 'see' and write certain DSCP values:
0 8 10 16 18 24 26 32 34 40 46 48 56
Depending on your IP Phones you can trust the CoS/DSCP received or reset it with a Serive-Policy.
Andy
