Voice Quality with 7912G IPPhone
pxrondin
Has anybody experimented a poor voice quality when using a 7912g with G729 Codec, whereas there is no QOS problem on the LAN. When we are using G711 Codec, on the same IPPhone, all is fine
The problem appears with several different 7912G
w-lam
check out this bug CSCuk46104. We have opened a TAC case for that and they have sent us a test phone load.
Thanks for your answer, I will open also a TAC case and I will claim to get the same firmware version to test
Patrick
