voice solution between 2 directly connected LAN
christianeze
hi,
we have 2 offices connected using microwave link p2p(using cisco routers at both ends).And we are about to deploy voice solution that will enable staff at both offices to make calls between the 2 offices using softphone technology. i need someone who have deployed this kind of solution before or have an idea of what it takes to help me with the tips of how to go about it.i wouldnt mind if diagram is attached.
thanks
Tommer Catlin
If they are on the same LAN, registered to the same CCM, the only thing you need to do is to configure the Cisco routers correctly for voice. RSVP works well now (not in the past) Setup some voice prirotization and you should be set. Usually the microwave boxes have low ms roundtrip times, do you should be ok for voice quality.
