VoIP across Frame Relay?
markw
Hello, I'm trying to get my head around putting in VoIP across a Frame Relay link. and im new to putting in QoS across frame.
We have the main office with call manager and a satellite office with 25 phones.
the link has a 2meg port speed with a 1meg CIR.
Can some one have a look at my config and let me know if i have done it right
thanks in advance
(I've only included the relevant parts of the config)
class-map match-all VoIP-Sig
match ip dscp af31
match ip precedence 3
match access-group name ACL-VoIP-Sig
class-map match-all VoIP-RTP
match ip dscp ef
match ip precedence 5
match access-group name ACL-VoIP-RTP
policy-map VOICE-POLICY
class VoIP-RTP
priority 480
class VoIP-Sig
bandwidth 16
class class-default
fair-queue
interface Serial0/0
no ip address
service-policy output VOICE-POLICY
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0/0.16 point-to-point
ip address 10.10.10.18 255.255.255.252
no ip route-cache
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 16 IETF
map-class frame-relay VOIPovFR
frame-relay cir 1024000
frame-relay bc 10240
frame-relay mincir 1024000
frame-relay fragment 320
ip access-list extended ACL-VoIP-RTP
permit udp any any range 16384 32768
ip access-list extended ACL-VoIP-Sig
permit tcp any eq 1720 any
permit tcp any any eq 1720
permit tcp any any eq 2000
permit tcp any eq 2000 any
j-macdonald
Are you running 12.2(15)T or higher IOS code? If so, the "auto qos voip" command makes life a lot easier. If you don't know a lot or aren't sure too sure about QoS configuration, it saves a lot of grief and misconfiguration. However, if you want to fine tune or go it the manual way, I do see something. Your frame relay fragment command is way to low. To calculate frame fragement you divide your CIR (1024) by 64 and multiply by 80. So in this case 16 X 80 = 1280. Frame-relay fragment should be 1280.
Hope that helps,
Best regards
John
