VoIP Management
tmoffett
Are there any "dashboard" real time at a glance packages for VoIP gateways? I am looking for software functionality that polls active call info and call history from a VoIP gateway and presents it in a dashboard view with the following:
busy hour
Active calls
Total
per peer
calls per hour
Total
Per peer
highwater mark active calls
Total
Per peer
Any ideas are greatly appreciated!
bwalchez
Level 4
Level 4
VoIP Health Monitor will give you some of the functionality you’re looking for (http://www.cisco.com/warp/public/cc/pd/wr2k/cvoip/index.shtml) but it’s currently on release 1.0 so it’s not as feature packed as you’d like. I’m sure this will improve with time.
try the NetIQ product http://www.netiq.com/products/vm/default.asp Seems to be pretty good.
