VOIP using a c2611 with a Inter-tel AXXESS IP Plus Keyset
jeff.breedlove
I am putting together a network for a remote site to WAN into our main site at our corporation. I have a Inter-tel Axxess Phone system which has a IPC card for VOIP. I have both routers fully configured. The way the phone works is it uses a static IP address and a default gateway and then it goes through the network to connect to the IPC card on the local side where the PBX is residing. The IP of the phone I am testing is 172.18.1.100 255.255.255.0, default Gateway 172.18.1.1 remote IPC 172.16.205.211 255.255.0.0 (On Local side with all Private IP's being class B). Their is an Enterasys Fast Ethernet Switch on Remote end of WAN IP 172.18.1.2 255.255.255.0, serial 0/0 172.17.1.2 on remote end of WAN, Local end of WAN 172.17.1.1 with a default gateway to the backbone 172.16.205.100 255.255.0.0. I can ping and tracert out through the network fine, but the IP phone can't resolve to the IPC card. I do a tracert to the IPC card from a client on the remote end and I can see it hitting 172.18.1.1, 172.17.1.1, and then it hits 172.16.205.211, but for some reason the phone can't connect to the card. I believe all of my programming in the router is correct. One note before we went with the config upons suggestion of Cisco we were using bridging with no IP routing and we were able to connect fine with the IPC card. When we reconfigured the routers with this current configuration we have yet to connect to the IPC card nor can we name resolve to the WINS server. We reconfigured because this current configuration will allow us to use QoS whereas bridging would not.
Local End of WAN where Phone system resides:
TBG_WAN1>enable
Password:
TBG_WAN1#show run
Building configuration...
Current configuration : 949 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname TBG_WAN1
enable password 7 05090905204249051C16
ip subnet-zero
no ip domain-lookup
bridge irb
interface Ethernet0/0
no ip address
no ip mroute-cache
full-duplex
bridge-group 1
interface Serial0/0
description connected to TBG_WAN2
ip address 172.17.1.1 255.255.255.0
no ip mroute-cache
service-module t1 remote-alarm-enable
interface Ethernet0/1
no ip address
no ip mroute-cache
full-duplex
bridge-group 1
interface BVI1
ip address 172.16.205.91 255.255.0.0
ip classless
ip route 172.18.1.0 255.255.255.0 172.17.1.2
ip route 172.19.1.0 255.255.255.0 172.17.1.2
no ip http server
ip pim bidir-enable
snmp-server community public RO
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
end
Remote end where IP phones reside:
TBG_WAN2#show run
Current configuration : 973 bytes
version 12.2
hostname TBG_WAN2
enable password
ip subnet-zero
no ip domain-lookup
ip address 172.18.1.1 255.255.255.0
ip helper-address 172.16.205.211
no ip mroute-cache
full-duplex
interface Serial0/0
description connected to TBG_WAN1
bandwidth 1536
ip address 172.17.1.2 255.255.255.0
ip tcp header-compression iphc-format
no ip mroute-cache
fair-queue 64 256 1
ip rtp header-compression iphc-format
ip rtp reserve 16384 100 768
ip address 172.19.1.1 255.255.255.0
no ip mroute-cache
half-duplex
ip classless
ip route 172.16.0.0 255.255.0.0 172.17.1.1
no ip http server
ip pim bidir-enable
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
TBG_WAN2#
Any suggestions will greatly be appreciated.
Jeff
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
