WebDialer with SOAP on CCM 3.3.3 or 3.3.4
jirka.novak
We tested HTTP interface od CCM 4.0 and 3.3.3, and now we would like to use SOAP for our applications. We are using URL:
http://SERVER/wdsoap/servlet/rpcrouter
On CCM 4.0 it works fine. But on 3.3.3 it returns error:
java.lang.NoClassDefFoundError: javax/mail/MessagingException
at org.apache.soap.server.http.RPCRouterServlet.init(RPCRouterServlet.java:239)
at javax.servlet.GenericServlet.init(GenericServlet.java:258)
at org.apache.tomcat.core.ServletWrapper.doInit(ServletWrapper.java:317)
at org.apache.tomcat.core.Handler.init(Handler.java:215)
at org.apache.tomcat.core.ServletWrapper.init(ServletWrapper.java:296)
at org.apache.tomcat.core.Handler.service(Handler.java:254)
at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
at org.apache.tomcat.service.connector.Ajp12ConnectionHandler.processConnection(Ajp12ConnectionHandler.java:166)
at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:416)
at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:498)
at java.lang.Thread.run(Unknown Source)
We tested it on three different servers with CCM 3.3.3 and/or 3.3.4 and all returns same error. On 4.0 CCM it works fine.
Does anyone has some idea?
Yours,
Jirka Novak
ckatene
Level 3
Level 3
according to
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ed128.html
the minimum requirement is call manager 4.0(1), so that would explain it.
it's just complaining about missing libraries, so it may work if you download the javamail libraries from the sun site (the activation framework is also required), and put them in the tomcat lib directory, but there may be other requirements.
and, of course, it wouldn't be supported.
callum
