11-24-2010 05:58 AM - edited 03-15-2019 05:13 AM
I am trying to get the pc phone to register through the webex client.
the work around i used that worked is the following....
I issued this command, on another machine using Windows XP, I got the file and copied it to the local directory of the machine that was having the issue, (that machine was running Windows 7 64 bit)
Tftp -i <server ip> GET <Device Name>.cnf.xml
the phone registers once the file was copied down.
Any Thoughts?
11-30-2010 02:30 PM
Could you run that command in the Windows 7 64 bit in the cmd?
I guess you couldnt.
Windows 7 by default has the tftp command disabled.
You can enable it by going to:
Control Panel -> Programs -> Turn Windows features on or off
Then activate the TFTP Client feature.
12-01-2010 04:55 AM
I was able to run the command. The issue only happened on one pc running Windows 7 64 bit. I successfully installed WebEx on other Windows 7 64 bit machines.
