Wierd Error on 2600 with FXO for Gateway
jfrelin
Getting this error in detailed trace on ccm with using a 2600 with a NM2v and a FXO port as a gateway for a couple phones in a lab environment...
Both Router and CCM show the gateway as registered to each other, I can see the fxo port ringing when I call into it, but It never answers (see it ringing by issuing a show voice port sum)
ios on router is: c2600-ik8o3s-mz.122-4.T1.bin
ccm v 3.2.1 (spA)
05/28/2002 21:36:45.088 Cisco CallManager|dBProcs -
ERROR - getProcessConfigInt. Cannot find entry.
paramName:RetryCountDRQ|<CLID::CCMPUB-Cluster>
<NID::CCMPUB>
05/28/2002 21:36:45.148 Cisco CallManager|dBProcs -
paramName:TimerRasDRQ|<CLID::CCMPUB-Cluster>
<NID::CCMPUB>
05/28/2002 21:39:50.639 Cisco CallManager|dBProcs -
<NID::CCMPUB>
<NID::CCMPUB>
05/28/2002 21:45:31.278 Cisco CallManager|
MGCPBhHandler 10.10.10.97 - ERROR -
MGCPNotificationRequest for reset: TCP Mgt not
supported by the GW. Sending MGCP err back to reload
device. GWTCPOpened=1, GWRegistered=1|<CLID::CCMPUB-Cluster>
<NID::CCMPUB><CT::1,100,89,1.246><IP::><DEV::>
05/28/2002 21:45:35.554 Cisco CallManager|DeviceUnregistered -
Device unregistered. Device name.:AALN/S1/SU0/0@cr1.testnetwork.net
Device IP address.:10.10.10.97 Device type.:121 Device description
[Optional].:AALN/S1/SU0/0@cr1.testnetwork Reason Code [Optional].:
9 App ID:Cisco CallManager Cluster ID:CCMPUB-Cluster Node ID:
CCMPUB|<CLID::CCMPUB-Cluster><NID::CCMPUB><CT::Alarm
AALN/S1/SU0/0@cr1.testnetwork.net><DEV::AALN/S1/SU0/0@
05/28/2002 21:45:45.538 Cisco CallManager|ProcessMGCPTrunk Started.
DeviceName = AALN/S1/SU0/0@cr1.testnetwork.net|<CLID::CCMPUB-Cluster>
05/28/2002 21:45:45.538 Cisco CallManager|MGCPBhHandler 10.10.10.97 -
ERROR - MGCPNotificationRequest for reset: TCP Mgt not supported
by the GW. Sending MGCP err back to reload device. GWTCPOpened=1,
GWRegistered=1|<CLID::CCMPUB-Cluster><NID::CCMPUB><CT::1,
05/28/2002 21:45:45.608 Cisco CallManager|DeviceUnregistered -
Device unregistered. Device name.:AALN/S1/SU1/0@cr1.testnetwork.net
Device IP address.:10.10.10.97 Device type.:120 Device description [Optional].:
AALN/S1/SU1/0@cr1.testnetwork Reason Code [Optional].:9 App ID:Cisco
CallManager Cluster ID:CCMPUB-Cluster Node ID:CCMPUB|<CLID::
CCMPUB-Cluster><NID::CCMPUB><CT::AlarmAALN/S1/SU1/0@
cr1.testnetwork.net><DEV::AALN/S1/SU1/0@cr1.testnetwork.net>
ciscomoderator
Community Manager
Community Manager
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
