XML fetch failed -- possibly a problem with AvXml.dll or its permissions
alh
When attempting to access the Status Monitor I receive the following error message:
XML fetch failed -- possibly a problem with AvXml.dll or its permissions.
Check that the "AvXml" virtual directory settings in IIS have proper permissions and allow execute access.
I've tried all combos of security on the IIS directory. What am I missing?
lindborg
Which version of Unity are you running?
This matches the description of a bug found in 4.0(x) that's been fixed but I don't think it's ever been seen prior to that... I'll check with the admin folks.
Sorry for the late response. We're on version 3.1.4.
Hi Lindborg
I have that problem with version 4.0 (X), it is due?, As I fix?.
Unity I have a failover cluster, I have several problems, sometimes not let me delete mailbox, I can retrieve messages.
thanks for any help you can provide.
Regard
