2232TM vs 2232TM-E
mitra dray
Hi !
need your help
i cant find the technical differences between  2232TM and 2232TM-E
only this :
N2K-C2232TM
Cisco Nexus 2232TM Series 10GBASE-T Fabric Extender, 2PS, 1 Fan Module, 32x1/10GBase-T + 8x10GE Module (req SFP+), choice of airflow and power supply
N2K-C2232TM-E
Cisco Nexus 2232TM-E Series 10GBASE-T Fabric Extender, 2PS, 1 Fan Module, 32x1/10GBase-T + 8x10GE Module (req SFP+), choice of airflow and power supply
why should i pick either ?
Thanks for the help which would be much appriciated
2 Accepted Solutions
Steve Fuller
Level 9
Level 9
Hi Mitra,
The main differences is the Ethernet PHY used in the 2232TM-E. As per the Product Bulletin:
with the same underlying architecture and the latest generation of the 10GBASE-T physical layer device (PHY), enabling lower power consumption and an improved bit-error rate (BER)
So basically you have lower power consumption and the option to run FCoE.
same issue with 2232TM-E and 2232TM-10GE...anyone know difference in those...can't find anywhere
Steve Fuller
Level 9
Level 9
Hi Mitra,
Thanks !
i think we have a winner so the 2232TM-E is FCOE supporting plus a low PW conmsumption and BER !
Thanks !!
2232 TM-E support FCOE but 2232TM not .
