AMA: Installation and Upgrade of Cisco HyperFlex
Brooke Hammer
Community Manager
Community Manager
Ask Me Anything Event
Welcome to the Cisco Support Community Ask Me Anything conversation. Are you using an old release of Cisco HyperFlex? Not the recommended one? You need to know more about the upgrade best practices? This session is for you. This session will focus on practical guidance on how to plan for a successful upgrade and deployment of Hyperflex, while avoiding common issues that may result in failures or outages. Join our experts in the AMA session, which will help simplify the HyperFlex upgrade and installation process.
Note: Please post your post as a comment below no later than May 26, 2023.
Post your question below by clicking "Reply"
(Answers will be processed depending on the availability of the experts)
Don't forget to thank the expert by giving it a helpful vote!
Our experts
Akash Malla is a Technical Consulting Engineer with Cisco HyperFlex solution team in Asia Pacific time zone. Currently, he is working as a Team lead for Cisco HyperFlex Team located in India. He has wide expertise in troubleshooting, managing, and deploying Cisco HyperFlex and Cisco UCS as a solution and is a contributor to the Cisco knowledge base. He holds an engineering degree in Electronics and Communications, and he is a Cisco Certified Specialist - Data Center Design.
Tarun Agarwal works in the Asia Pacific region as a Technical Consulting Engineer for the Cisco HyperFlex solution team. He has around 9 years of expertise in server virtualization domain. He is now working in India as a Team Lead for the Cisco HyperFlex Team. He has extensive experience designing, implementing, and troubleshooting Cisco Hyperflex, UCS, and VMware solutions. He holds a bachelor's degree in Electronics and Communications engineering and is a VMWare Certified Professional.
10 Replies 10
Siddharth Dhingra
Can we perform hyperflex deployment when the servers are integrated with single link only?
Hi Siddharth,
Thank you for your query.
Single link deployment would not work. HX installer will try to deploy the vNICs on both fabrics and association will fail in case of single active link.
Preinstallation Checklist for Cisco HX Data Platform also explains this as a note : "Single FI HX deployment is not supported." (https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/HyperFlex_Preinstall_Checklist/b_HX_Data_Platform_Preinstall_Checklist.html)
Please feel free to post, in case any further queries.
Akash Malla
** Please rate if you found the post helpful **
Mehul More
Hi Team,
We are planning to Change IP Schema of HX Cluster. Need to know which are the precaution steps We need to follow.
Mehul More
Hello Mehul,
Changing Hyperflex management IPs is a TAC supported workflow. Open a TAC case and our engineers will help you with the flow.
Changing Hyperflex data IPs requires re-installing the cluster from scratch (backup/wipe/redeploy).
Let me know if you have further queries on that.
Akash Malla
Mehul More
Hi Team,
During Upgrade We face issue Like During Esxi upgrade "Configuration Upgrade Failure
Please reboot to rollback to the older version
Failed modules:
/usr/lib/vmware/configmanager/upgrade/lib/libupgradesnmpmodule.so
Hello Mehul,
Thank you for your query, there is a KB article reporting similar condition https://kb.vmware.com/s/article/76239
To workaround this issue
  1. Reboot the ESXi host to revert to the previous version.
  2. Replace weak authentication protocol (MD5) with SHA1 and reconfigure v3 users.
  3. Now perform the upgrade.
Note : In case you are not using the snmp configuration, we have also seen cases where a reset of SNMP configuration to default can be done using command "esxcli system snmp set -r" and upgrade can be tried again.
JFI,Your snmp configuration can be checked using command "esxcli system snmp get"
Rahil Abrol
Hi All,
Any documentation for port requirements for hyperflex? Need some detailed info.
Thank you
Hello Rahil,
Port requirement is briefly explained in HyperFlex hardening guide :   https://www.cisco.com/c/dam/en/us/support/docs/hyperconverged-infrastructure/hyperflex-hx-data-platform/HX-Hardening_Guide.pdf
Please review "Appendix A: Networking Ports"
Akash Malla
Rahil Abrol
Tried to change the cluster and datacenter name in VC, is that all or do I need to do something from HX?
Thank you
Hello Rahil,
There is a Reregistration Process that needs to be executed from the controller VM.
The process is explained over link:  https://www.cisco.com/c/en/us/support/docs/hyperconverged-infrastructure/hyperflex-hx-data-platform/214504-ucs-hyperflex-changing-vcenter-cluster.html
We have a video published as well for same : https://www.youtube.com/watch?v=QqJQRCaQmk0
Akash Malla
