ASA clustering and remote access VPN with security contexts
Jeremy Dubrulle
Hi, I'm new with ASA. I've found that we can't use remote access VPN with asa clustering. But is it possible to cluster one virtual security context on each of both asa, and use remote access VPN on another security context ?
Philip D'Ath
You can use remote access VPN (AnyConnect) with clustering.  You don't need to go into multi-context mode to do this.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/vpnsysop.html#wp1048834
MARK BAKER
Level 4
Level 4
ASA clustering is done on the system context when in multi mode. RA VPN is not supported on any of the contexts on the firewall when clustering. This is my understanding of it. We are clustering in multi mode and clustering is done on the system context. I check back from time to time to see if RA VPN support has been added, but haven't seen that it is yet.
