06-18-2012 08:27 AM - edited 03-01-2019 07:07 AM
With Prashanth Krishnappa
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn about how to troubleshoot the Nexus 5000/2000 series switches.
Prashanth Krishnappa is an escalation engineer for datacenter switching at the Cisco Technical Assistance Center in Research Triangle Park, North Carolina. His current responsibilities include escalations in which he troubleshoots complex issues related to the Cisco Catalyst, Nexus and MDS product lines as well as providing training and author documentation. He joined Cisco in 2000 as an engineer in the Technical Assistance Center. He holds a bachelor's degree in electronics and communication engineering from Bangalore University, India, and a master's degree in electrical engineering from Wichita State University, Kansas. He also holds CCIE certification (#18057).
Remember to use the rating system to let Prashanth know if you have received an adequate response.
Prashanth might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Data Center sub-community discussion forum shortly after the event. This event lasts through June 29, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
09-24-2012 12:33 PM
Hi Prashanth. A pleasure to greet, my name is Samuel. I am trying to set certain SNMP commands in the Nexus 7000 in our network, to monitor the computer for any problems and do not know where to configure them.
On a Cisco router I can configure it normally, but, in the Nexus does not.
The commands are as follows on a Cisco router:
access-list 80 permit xx.xx.xx.xx 0.0.0.255
access-list 81 permit xx.xx.xx.xx 0.0.0.255
snmp-server community bMc-pupl!c RO 80
snmp-server community bMc-pr!V4t3 RW 81
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps syslog
snmp-server host xx.xx.xx.xx bMc-pupl!c
¿As I can do the same in the NEXUS?
They help me with this problem please
thanks
09-27-2012 03:21 PM
Hi Samuel
This event is closed. But I will try to answer it. I do see an option for use-acl in my switch.
20-11-7010-N7k-Core-A(config)# snmp-server community public use-acl ?
WORD Acl name to filter snmp requests (Max Size 32)
-Prashanth
09-25-2012 01:10 PM
A quick question about port-channel load balancing algorithms on a Nexus 5020. Can I change the algorithm on the fly without adverse affects? I need to change from "source dest IP" to "source dest port" but I am worried about what happens to my port channels while I make this change.
Marc
09-27-2012 03:22 PM
Hi Marc
This event is closed but I will try to answer your question. You can make load-balancing change with no impact
-Prashanth
10-01-2012 12:49 AM
hi ,
i have two Cisco Nexus 5k's in vpc and and cisco fex 2k and cisco 2960 switch as access layer in downstream.
configured vtp on both 5k's and whenever i am trying to add or delete vlan on N5K server switch the revision number does not increase and the vlans not propagating to the down stream switches.
can you please help me in this case
regards ,
Mithun ghosh
04-26-2013 04:50 AM
I am trying to configure FHRP with two Nexus 5K With no vPC in SVI's but i cant make one of them "passive". It seems to be an issue with incoming hellos because i have connected a 3750 to both of them in the same vlan and i have runn debugs. The test fails with VRRP in SVIs and HSRP in SVIs
This test is with only one 5k and a 3750 with HSRP
Run in N5K
interface Vlan1712
no shutdown
description LAN DMZ PrivateCORP
ip address 10.208.204.2/24
hsrp 111
authentication text test
preempt
priority 150
ip 10.208.204.1
N5K_Esperanza_1#
N5K_Esperanza_1#
N5K_Esperanza_1#
N5K_Esperanza_1# sh hsrp brief
P indicates configured to preempt.
Interface Grp Prio P State Active addr Standby addr Group addr
Vlan1712 111 150 P Active local unknown 10.208.204.1 (conf)
N5K_Esperanza_1#
Debug
N5K_Esperanza_1# 2013 Apr 25 21:14:14.812585 hsrp: Vlan1712[111/V4]: Hello out Active pri 150 ip 10.208.204.1
2013 Apr 25 21:14:14.812605 hsrp: Vlan1712[111/V4]: hel 3 hol 10 auth test
2013 Apr 25 21:14:17.812686 hsrp: Vlan1712[111/V4]: Hello out Active pri 150 ip 10.208.204.1
2013 Apr 25 21:14:17.812708 hsrp: Vlan1712[111/V4]: hel 3 hol 10 auth test
2013 Apr 25 21:14:20.812683 hsrp: Vlan1712[111/V4]: Hello out Active pri 150 ip 10.208.204.1
2013 Apr 25 21:14:20.812705 hsrp: Vlan1712[111/V4]: hel 3 hol 10 auth test
Run in 3750 connevted via trunk to N5K
interface Vlan1712
ip address 10.208.204.10 255.255.255.0
standby 111 ip 10.208.204.1
standby 111 priority 190
standby 111 preempt
standby 111 authentication test
end
Debug
SW2_3750_LAB#
Apr 25 18:14:20: HSRP: Vl1712 Grp 111 Hello out 10.208.204.10 Active pri 190 vIP 10.208.204.1
Apr 25 18:14:20: HSRP: Vl1712 Grp 111 Hello in 10.208.204.2 Active pri 150 vIP 10.208.204.1
SW2_3750_LAB#
It seem to be working OK in 3750 but N5K thinks he is the only one int the LAN and assumes itself as Active
NX-OS is
n5000-uk9.5.1.3.N2.1.bin
Hope you can help
Best Regards
Gonzalo Díaz
10-25-2013 07:52 AM
hi
Hope you can assist on nexus 5020.
we had a faulty psu from nexus 2232 Fex. A replacement was done. But fex did not restart after replacement. Had to reseat the psu and then fex restarted. Is this a default behaviour. Thank you.
Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public License. A copy of the license is available at http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 1.5.0
loader: version N/A
kickstart: version 5.1(3)N1(1a)
system: version 5.1(3)N1(1a)
power-seq: Module 1: version v1.2
BIOS compile time: 11/30/10
kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1a.bin
kickstart compile time: 2/7/2012 23:00:00 [02/08/2012 18:49:30]
system image file is: bootflash:///n5000-uk9.5.1.3.N1.1a.bin
system compile time: 2/7/2012 23:00:00 [02/08/2012 23:44:33]
PID: N2200-PAC-400W
11-24-2013 05:42 AM
I'm using the B22 FEX module in our HP C7000 chassis. Somehow, i'm recieving alot of messages in my log saying : Interface Ethernet xx/1/xx is down (Error disabled. Reason:ekeying triggered). My Fex is connected to a Nexus5596 : 5.2(1)N1(4). I did not see that kind of messages on my old 5010 switches.
What is the reason (all though i suspect servers booting) and can one disable the messages?
Regard Steffen Webb
02-13-2014 06:29 AM
Same here. any way of disabling these messages ? even shutdown of interface won't help
