10-06-2015 09:11 AM - edited 03-01-2019 08:03 AM
Hi All,
i have strange problem, My ASR1001-x is using all its available bootflash space and i can't see whats using it
Router#dir
Directory of bootflash:/
11 drwx 16384 Apr 6 2015 02:08:07 +00:00 lost+found
112673 drwx 4096 Oct 6 2015 08:40:19 +00:00 .prst_sync
12 -rw- 489740544 Apr 6 2015 02:10:09 +00:00 asr1001x-universalk9.
03.13.02.S.154-3.S2-ext.SPA.bin
96577 drwx 4096 Apr 6 2015 02:11:42 +00:00 .installer
434593 drwx 4096 Oct 6 2015 07:20:56 +00:00 core
305825 drwx 4096 Apr 6 2015 02:38:13 +00:00 .rollback_timer
13 -rw- 0 Apr 6 2015 02:38:21 +00:00 tracelogs.848
64385 drwx 16384 Oct 6 2015 08:46:42 +00:00 tracelogs
14 -rw- 1148 Sep 21 2015 07:51:32 +00:00 JAE1843005S_201509210
100857810.lic
6741659648 bytes total (0 bytes free)
Router#
I was thinking i could format the bootflash but if i do, will i loose the adventerprise license ( the license is the in the bootflash is for throughtput), i don't have a backup of the adventerprise license
any help greatly appreicated
10-06-2015 11:52 PM
Have you tried dir /all /recursive to see if there are any files in sub-directories?
If you want to format the bootflash: you could copy the license file to an alternate location such as USB, TFTP, FTP, SCP server etc., and then copy it back after.
10-07-2015 09:54 AM
thanks for getting back to me steve , i can backup the license showing (throughput license), but the adventerprise license i don't have the .lic file in the flash
10-07-2015 09:59 AM
OK. If you have the Product Activation Key (PAK) for the router you should be able to create a new license file.
Did the dir /all /recursive show any files that would seem to be consuming all the space?
