ASR1001-X eUSB 6741659648 bytes total (0 bytes free)
billybong
Hi All,
i have strange problem, My ASR1001-x is using all its available bootflash space and i can't see whats using it
Router#dir
Directory of bootflash:/
   11  drwx            16384   Apr 6 2015 02:08:07 +00:00  lost+found
112673  drwx             4096   Oct 6 2015 08:40:19 +00:00  .prst_sync
   12  -rw-        489740544   Apr 6 2015 02:10:09 +00:00  asr1001x-universalk9.
03.13.02.S.154-3.S2-ext.SPA.bin
96577  drwx             4096   Apr 6 2015 02:11:42 +00:00  .installer
434593  drwx             4096   Oct 6 2015 07:20:56 +00:00  core
305825  drwx             4096   Apr 6 2015 02:38:13 +00:00  .rollback_timer
   13  -rw-                0   Apr 6 2015 02:38:21 +00:00  tracelogs.848
64385  drwx            16384   Oct 6 2015 08:46:42 +00:00  tracelogs
   14  -rw-             1148  Sep 21 2015 07:51:32 +00:00  JAE1843005S_201509210
100857810.lic
Router#
I was thinking i could format the bootflash but if i do, will i loose the adventerprise license ( the license is the in the bootflash is for throughtput), i don't have a backup of the adventerprise license
any help greatly appreicated
Steve Fuller
Level 9
Level 9
Have you tried dir /all /recursive to see if there are any files in sub-directories?
If you want to format the bootflash: you could copy the license file to an alternate location such as USB, TFTP, FTP, SCP server etc., and then copy it back after.
thanks for getting back to me steve , i can backup the license showing (throughput license), but the adventerprise license i don't have the .lic file in the flash
OK. If you have the Product Activation Key (PAK) for the router you should be able to create a new license file.
Did the dir /all /recursive show any files that would seem to be consuming all the space?
