07-19-2020 12:56 PM
Setting up Linux (CentOS) workstation as a development environment
As per page 8/10 at https://developer.cisco.com/learning/modules/dev-setup/dev-centos/step/8,
'sudo yum install -y docker-ce' resulted in:
package docker-ce-3:19.03.12-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
Solved! Go to Solution.
07-19-2020 01:10 PM
Manual installation (as root) of containered.io package resolved the issue
yum install -y https://download.docker.com/linux/centos/7/x86_64/stable/Packages/containerd.io-1.2.6-3.3.el7.x86_64.rpm
Install Docker CE again after manual installation of the package:
07-19-2020 01:10 PM
