11-13-2017 07:59 AM - edited 03-01-2019 08:40 AM
Hi..
We wanted to delete admin user from our nexus switches, but from the discussion, I understand that we can not delete or remove this admin user.
Is there any other option to restrict this admin user access?? No one can access,read-write with this access.
Thanks in adavance.
Vinay
Solved! Go to Solution.
11-13-2017 08:01 AM
The "admin" user account should be looked at like the "root" user in Linux. You should create a password for admin and then not use it as an account that is accessed regularly, unless absolutely necessary.
If you want to create a "super-user" create a new local user with admin privileges or restrict that user accordingly. You are not able to modify "admin" by design.
11-13-2017 08:01 AM
