Difference between F3 and M3 modules on the Nexus 7700
Martin Hruby
Hello all
We are looking install a new data center core switch based on the Nexus 7700 platform, probably the 7702 or 7706.
We do not require many features, just the classic OSPF, VRF-Lite, vPC, 4x VDC...
Now I know in the past there were quite big differences between the F and M series modules when it came to supported features.
Can someone please clarify what are the main differences between the F3 (N77-F348XP-23) and M3 (N77-M348XP-23L) for the Nexus 7700 with Sup2E ? Which one should we choose for our Nexus 7700?
Thanks and best regards,
Martin
nazimkha
Level 4
Level 4
Hi Martin,
Major difference is the scale and table size.
A comprehensive comparison can be found in the below link :
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/nexus7000/sw/matrix/technical/reference/Module_Comparison_Matrix.pdf
Nazim
