difference between N7K-SUP1-BUN and N7K-SUP1- ?
TruthSeeker
What does the suffix BUN stand for ?
what are the meanings of  suffix  " = " , " BUN " and " -  ?
N7K-SUP1-BUN"  ,  "N7K-SUP1- "  ,  "N7K-SUP1= "
bravocarlos
the "BUN" part usually means that the item is part of a "Bundle" meaning it is sold in a combination with other items. The "=" sign at the end usually means that the part is a spare, it is not sold as part of a configuration but as an extra item to replace a failed item.
Greetings,
C.
BraovCalos is correct, it just depends on how you plan to order the Supervisor
BUN= Usually included as part of a bundled part number, I.E. comes bundled with the Chassis, Power supplies, and fan modules.
= = This you are ordering as a spare part where you have an existing N7K with one Sup and you want to add another.
-= This usually as some type of name convention after it like N7K-SUP1-8GBUPG
By the way SUP1 has reached end of life and is no longer orderable except for memory upgrades.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/end_of_life_notice_c51-729282.html
