Does FabricPath relies only on IS-IS hello exchange to detect link failures or does it implement BFD (Bidirectional Forwarding Detection)?
doctor_1602
I'm trying to understand if FabricPath relies only on IS-IS hello exchange to detect link failures or if it implements BFD (Bidirectional Forwarding Detection) to reduce the failure detection time. I noticed n RFC to introduce BFD in TRILL signed by a person from Cisco, so I was wondering if they adopted that in FP.
Thanks.
Jerry Ye
FP uses IS-IS hello to detect link failures. In a DC environment, P2P link is used to interconect FP and FP IS-IS will react to port down notification.
HTH,
jerry
6 Replies 6
Jerry Ye
HTH,
jerry
So.. it doesn't wait for a certain time after which if no hellos are received the link is considered down. It react as soon as a port down notification is received... right?
So what if aggregated links are used? How does it behave?
If it is inside the same DC with P2P link, yes. FP will react when it detects port down.
I am assuming aggregated links means DWDM to another DC. If this is what you mean, then it will rely on the IS-IS hello timer.
I was wondering about a Link Aggregation Group or what Cisco refers to as EtherChannel. I guess it is possible to use these links between switches... right?
Yes, EtherChannel/Port-Channel is preferred to connect between FP nodes, and Port-Channel will behave the same link the individual link (it is P2P).
Thanks a lot!
