03-09-2011 05:41 AM - edited 03-01-2019 06:55 AM
Can somebody post a complete set of configuration for a double sided vPC between Nexus 7K and 5K pairs?
Thank you,
Mohan
03-12-2011 06:49 AM
Its just like any other vPC configuration but just make sure the vPC domain ID is different on 7ks and 5ks. Here are sample configurations from
my lab set up (Po999 is my vPC from the N7k to N5k)
N7K-24-13-7010-1-prkrishn-7010-2# sh run vpc
!Command: show running-config vpc
!Time: Sat Mar 12 09:46:41 2011
version 5.1(2)
feature vpc
vpc domain 1
role priority 1000
peer-keepalive destination 1.1.1.2 source 1.1.1.3 vrf vpc-keepalive
peer-gateway
interface port-channel1
vpc peer-link
interface port-channel998
vpc 998
interface port-channel999
vpc 999
24.10.5020B.1# sh run vpc
!Time: Sat Mar 12 09:46:04 2011
version 5.0(3)N1(1a)
feature vpc
vpc domain 1000
peer-keepalive destination 10.10.10.1
interface port-channel18
vpc 18
interface port-channel100
vpc 100
interface port-channel101
vpc 101
vpc 999
interface port-channel1000
vpc peer-link
03-13-2011 04:00 AM
Thank you for posting the configs for me prkrishn.
My question is, for a double-sided-vPC, do we have to use the same vPC numbers on 7K and 5K? I mean, in your configuration, the vPC numbers on 5k must also be 999, right?
If possible, can you please post the relevant N5K configs. as well?
Thank you,
Mohan
