Fex 1 Nexus 2148 to 2 Nexus 5010 problem?
hatv
hi all
I'm having trouble when fex(ing) 1 nexus 2000 to 2 nexus 5000.
I've configured as dual home from 1 nexus 2k. But after success config, just 1 nexus 5k can see 48 port on it. other cannot see it and it showed as module offline
Here's is results:
N5K-01(config-if)# sh int e1/4 fex-intf
Fabric           FEX
Interface        Interfaces
Eth1/4
N5K-01(config-if)#
N5K-02# sh int e1/4 fex-intf
Fabric           FEX
Eth1/4          Eth100/1/48   Eth100/1/47   Eth100/1/46   Eth100/1/45
                 Eth100/1/44   Eth100/1/43   Eth100/1/42   Eth100/1/41
                 Eth100/1/40   Eth100/1/39   Eth100/1/38   Eth100/1/37
                 Eth100/1/36   Eth100/1/35   Eth100/1/34   Eth100/1/33
                 Eth100/1/32   Eth100/1/31   Eth100/1/30   Eth100/1/29
                 Eth100/1/28   Eth100/1/27   Eth100/1/26   Eth100/1/25
                 Eth100/1/24   Eth100/1/23   Eth100/1/22   Eth100/1/21
                 Eth100/1/20   Eth100/1/19   Eth100/1/18   Eth100/1/17
                 Eth100/1/16   Eth100/1/15   Eth100/1/14   Eth100/1/13
                 Eth100/1/12   Eth100/1/11   Eth100/1/10   Eth100/1/9
                 Eth100/1/8    Eth100/1/7    Eth100/1/6    Eth100/1/5
                 Eth100/1/4    Eth100/1/3    Eth100/1/2    Eth100/1/1
N5K-01(config-if)# sh fex 100 detail
FEX: 100 Description: FEX0100   state: Offline
  FEX version: 4.1(3)N2(1a) [Switch version: 4.1(3)N2(1a)]
  FEX Interim version: 4.1(3)N2(1a)
  Switch Interim version: 4.1(3)N2(1a)
  Extender Model: N2K-C2148T-1GE,  Extender Serial: JAF1405CKHC
  Part No: 73-12009-06
  Card Id: 70, Mac Addr: 00:0d:ec:fd:48:82, Num Macs: 64
  Module Sw Gen: 12594  [Switch Sw Gen: 21]
pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/4
  Fabric interface state:
    Eth1/4 - Interface Up. State: Active
  Fex Port        State  Fabric Port  Primary Fabric
       Eth100/1/1  Down      Eth1/4      Eth1/4
       Eth100/1/2  Down      Eth1/4      Eth1/4
       Eth100/1/3  Down      Eth1/4      Eth1/4
       Eth100/1/4  Down      Eth1/4      Eth1/4
       Eth100/1/5  Down      Eth1/4      Eth1/4
       Eth100/1/6  Down      Eth1/4      Eth1/4
       Eth100/1/7  Down      Eth1/4      Eth1/4
       Eth100/1/8  Down      Eth1/4      Eth1/4
       Eth100/1/9  Down      Eth1/4      Eth1/4
      Eth100/1/10  Down      Eth1/4      Eth1/4
      Eth100/1/11  Down      Eth1/4      Eth1/4
      Eth100/1/12  Down      Eth1/4      Eth1/4
      Eth100/1/13  Down      Eth1/4      Eth1/4
      Eth100/1/14  Down      Eth1/4      Eth1/4
      Eth100/1/15  Down      Eth1/4      Eth1/4
      Eth100/1/16  Down      Eth1/4      Eth1/4
      Eth100/1/17  Down      Eth1/4      Eth1/4
      Eth100/1/18  Down      Eth1/4      Eth1/4
      Eth100/1/19  Down      Eth1/4      Eth1/4
      Eth100/1/20  Down      Eth1/4      Eth1/4
      Eth100/1/21  Down      Eth1/4      Eth1/4
      Eth100/1/22  Down      Eth1/4      Eth1/4
      Eth100/1/23  Down      Eth1/4      Eth1/4
      Eth100/1/24  Down      Eth1/4      Eth1/4
      Eth100/1/25  Down      Eth1/4      Eth1/4
      Eth100/1/26  Down      Eth1/4      Eth1/4
      Eth100/1/27  Down      Eth1/4      Eth1/4
      Eth100/1/28  Down      Eth1/4      Eth1/4
      Eth100/1/29  Down      Eth1/4      Eth1/4
      Eth100/1/30  Down      Eth1/4      Eth1/4
      Eth100/1/31  Down      Eth1/4      Eth1/4
      Eth100/1/32  Down      Eth1/4      Eth1/4
      Eth100/1/33  Down      Eth1/4      Eth1/4
      Eth100/1/34  Down      Eth1/4      Eth1/4
      Eth100/1/35  Down      Eth1/4      Eth1/4
      Eth100/1/36  Down      Eth1/4      Eth1/4
      Eth100/1/37  Down      Eth1/4      Eth1/4
      Eth100/1/38  Down      Eth1/4      Eth1/4
      Eth100/1/39  Down      Eth1/4      Eth1/4
      Eth100/1/40  Down      Eth1/4      Eth1/4
      Eth100/1/41  Down      Eth1/4      Eth1/4
      Eth100/1/42  Down      Eth1/4      Eth1/4
      Eth100/1/43  Down      Eth1/4      Eth1/4
      Eth100/1/44  Down      Eth1/4      Eth1/4
      Eth100/1/45  Down      Eth1/4      Eth1/4
      Eth100/1/46  Down      Eth1/4      Eth1/4
      Eth100/1/47  Down      Eth1/4      Eth1/4
      Eth100/1/48  Down      Eth1/4      Eth1/4
Logs:
[11/24/2010 03:16:20.624283] Module register received
[11/24/2010 03:16:20.627639] Registration response sent
[11/24/2010 03:16:21.115021] Module Online Sequence
[11/24/2010 03:16:22.379395] Module Online
[11/24/2010 03:52:09.779773] Module disconnected
[11/24/2010 03:52:09.781691] Offlining Module
[11/24/2010 03:52:09.782231] Module Offline Sequence
[11/24/2010 03:52:11.735462] Module Offline
[11/24/2010 04:06:25.258659] Module disconnected
[11/24/2010 04:06:25.259890] Offlining Module
N5K-02# sh fex 100 detail
FEX: 100 Description: FEX0100   state: Online
Logs:
[11/24/2010 03:49:38.824900] Module timed out
[11/24/2010 03:54:08.225000] Module register received
[11/24/2010 03:54:08.226093] Registration response sent
[11/24/2010 03:54:08.540805] Module Online Sequence
[11/24/2010 03:54:10.7287] Module Online
Anyone can help me with this?
Thanks.
Ozden Karakok
You can only have one FEX module active with a dual home from one Nexus 2K to two Nexus 5K if you DON'T configure vPC.
If you want to achieve Active/Active topology which means FEX module is online from both N5Ks,you have to configure vPC on both N5Ks
If we look at the FEX logs for N5K-01 and N5K-02, N5K-01 became offline as soon as the N5K-02 became online, this is an expected behaviour without vPC.
You can check the below design guide for the configuration and the design options. (start from page 23 for N2K)
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572829-01_Design_N5K_N2K_vPC_DG.pdf
I hope this answers your question.
Ozden
6 Replies 6
Ozden Karakok
Ozden
I already configured vPC between 2 Nexus 5010
N5K-01# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
vPC role                        : primary
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1
vPC status
id     Port        Status Consistency Reason                     Active vlans
100    Po100       down   success     success                    -
N5K-02# sh vpc
Legend:
vPC domain id                   : 1
vPC role                        : secondary
1    Po1    up     1
vPC status
100    Po100       down*  success     success                    -
N5K-02#
may i miss some config ?
I've configured success. !
I've made mistake cause i used physical interface to FEX and not use Portchannel to fex.
Thanks.
Super :-) , thanks for the confirmation.
Hi.
It work perfect like charm yesterday but today i've checked it again and i saw down( INACTIVE) in interface fex 100/1/1- 100/1/48 and my network cannot go thought.
I checked them with "sh vpc consistency-parameters interface e100/1/1" and no different between local and peer.
N5K-01# sh vpc consistency-parameters int e100/1/1
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Speed                       1     1000 Mb/s              1000 Mb/s
Duplex                      1     full                   full
Port Mode                   1     access                 access
Shut Lan                    1     No                     No
Allowed VLANs               -     21                   21
After that, i switched all port to vlan 1 default and all interface UP state, and i switched all interface to vlan 21 on 2 switch 5000 and i saw INACTIVE again?
What happened?
Vlan 1 work but vlan 21 Down ? May i wrong something ? It worked and became failed after 12h ?
Thanks.
Ming_Prince
I wonder if you have allowed vlan 21 in the peer link? if not, this can cause interface to go to inactive as well.
