i cant see any simulated leaf/spine switches in ACI Simulator like mention on the ACI Simulator documentation
Ibrahim Jamil
Level 6
Level 6
Hello guys
I installed ACI Simulator 2.x on Vmware workstation 12.0 , I got successful installation iregardless of the UCS Hardware being used
the problem is  i cant see any simulated leaf/spine switches like mention on the ACI Simulator documentation
any help , how can i show up these simulated switches
thanks
takcheun@cisco.com
Try to use the default values in the APIC setup wizard but the mgmt and GW address. My problem was using the non-default VLAN for infra network, once I used default value 4, I am able to see the first leaf, discovered the fabric.
takcheun@cisco.com
Hi takcheun
thanks bro , you solved my issue , thanks May God bless you
thanks
what do u mean by Value 4 " My problem was using the non-default VLAN for infra network, once I used default value 4" is it the VLAN ID = 4 ??? >>> Yes
Try to use the default values in the APIC setup wizard but the mgmt and GW address. ??? >>> Use your own IP addresses.
