icmp drops in the same subnet
elite2010
Level 3
Level 3
Hi ,
a vm cannot ping the  anothe vm in the same subnet . At the same time  from other vlan  it is reachable .
vm is connected to nexus switch where vpc is running .
s.lachica
Check the physical interfaces, especially port-channels. There might be bad physical links.
CCIE (R&S) #27666 CCSI HP MASE
Ganesh Hariharan
Hi ,
VM is generally be in some vendor specific chassis, could you please check the VNIC configuration for both the VMS are in same vlan tagged and in same subnet and mask.
Hope it Helps..
-GI
Rate if it Helps..
