ISSU upgrade from 6.2( 2) to 6.2(6 ) - % URIB -3- ADD_PATH_ERROR
jgeralsky
After an ISSU upgrade from 6.2 ( 2) to 6.2 (6 ) we regularly receive the following warning messages in the log :
Dec 30 09:13:57 CSR1 - krr.lrz.de : 2013 Dec 30 08:13:57 UTC: % URIB -3- ADD_RPATH : urib [ 8038 ] ( default- base) Client " MBGP - 12816 " added 199 109 . 32.0/24 via not found rnh % 129.187.0.1/32 default
Dec 30 09:13:57 CSR1 - krr.lrz.de : 2013 Dec 30 08:13:57 UTC: % URIB -3- ADD_RPATH : urib [ 8038 ] ( default- base) traceback : 0x80d5bd9 0x80db128 0x80e214b 0x808e6b6 0x8092a56 librsw . libpthread.so.0 +0 x6140 so +0 xaa14f libc.so.6 +0 xca8ce
Dec 30 09:13:57 CSR1 - krr.lrz.de : 2013 Dec 30 08:13:57 UTC: % URIB -3- ADD_PATH_ERROR : urib [ 8038 ] ( default- base) urib_process_modify_routes : could not add path for client " MBGP - 12816 " .
The prefix is always 199.109.32.0/24  or 199.109.32.0/22 . The other 4000 prefixes we don't get this message .The nexthop 129.187.0.1 is for all 4000 + prefixes .
Why we get these error messages ?
How can we fix it ?
Thank you,
Jan
nnils
it seems to be fixed in 6.2.8
Nils
jgeralsky
Cisco case was opened 3 months ago and still trying to figure out the root cause.
I can provide partial update if is it necessary.
Jan
Hello Jan,
we opened a case last week.
We see also the same problematic bgp route 199.109.32.0/24, but we both get the routes via DFN.
Nils
Hello Nils,
Our case number is SR#628654113.
Cisco DEV team is working on it. They still need some new outputs.
Cisco suspecting it to be an issue with urib memory leak.
Jan
nnils
Nils
