04-03-2015 10:55 AM - edited 03-01-2019 07:52 AM
In a UCS 220 M3 server I continue to get Authorization failure when trying to use the KVM through the CIMC. The user is set for admin rights. I have tried creating another user and giving them user rights and admin rights but still get the same results - KVM: Auth failure. Any suggestions?
04-04-2015 06:09 PM
what Java version are you using? does this happen no matter what PC is used?Are all those PCs using the same java version?
-Kenny
04-06-2015 10:08 AM
I have two new UCS 220 M3 servers I am trying to set up with the same results. I tried three different laptops with the same results also. Two are running java 1.7.0_76-b13 and the third is running Java 1.7.0_67-b01. I went through the Cisco KVM troubleshooting guide - 115958-ucsm-kvm-troubleshooting-00 to no avail. When trying to download the KVM.zip I get a 404 - file not found.
04-06-2015 07:36 PM
What Web browser are you using? And is there any firewall blocking the KVM ports?
-Kenny
04-07-2015 10:42 AM
I tried Firefox and Explorer to no avail and the firewall was turned off on each of the machines. I made an exception in the firewall for the port 2068 described in the kvm troubleshooting guide by Cisco and turned the firewall on but still no difference.
04-07-2015 10:46 AM
If you enable Java logging, what do you see? Do you have more than one Java version installed or just one? I have seen issues when there is more than one Java version installed causing conflicts.
-Kenny
04-07-2015 05:12 PM
Here is the logging output:
Java Web Start 10.76.2.13
Using JRE version 1.7.0_76-b13 Java Hotspot(TM)64-Bit Server VM
User home directory= C:\Users\administrator.SMC
Command decriptions removed for brevity.
Missing Application-Name manifest attribute for: https://192.168.255.171:443/software/avctNuova.jar
KVM/VM Client Version: 5.03.01(Build 223)
replace numpad
replace numpad
**Max Size: W = 1920 H = 1160
**Window Pref Size: W = 1040 H = 826
JNLPClassLoader: Finding library VMAPI_DLL.dll
JNLPClassLoader: Finding library jawt.dll
JNLPClassLoader: Finding library avctKVMIO.dll
ProtocolAPCP.ReceiveSessionSetup: v1.2APCP = true
APCP Version 258
server sends a HB timeout = 60
Supported protocols:[SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2]
Enabled protocols: [SSLv3, TLSv1, TLSv1.1, TLSv1.2]
Supported Ciphers: removed for brevity.
Enabled Ciphers: removed for brevity.
SSL session using protocol: removed for brevity.
KVMIOWindowListener::setup
There doesn't seem to be anything of interest there.
I am running only one version of Java.
04-09-2015 05:25 AM
Is it possible for you to try Java 7 u21? I have seen that version always works... by the way, what is the CIMC version you are running?
-Kenny
04-09-2015 09:28 AM
I'll see if I can put the Java 7 u21 on the machine today and try it.
I have the 2.0 (3d) version of CIMC on the UCS servers.
04-21-2015 10:53 AM
Well I finally got to get back to this problem but the Java 7u21 still does not work. I did get different results however. I got a message box that said "The session timed out waiting for verification of the certificate. All the connections will be closed."
The Java console looks the same however.
04-21-2015 11:44 AM
The logs for the CIMC did not show the auth fail message however.
