LISP: difference platform ping each other UNREACHABLE.
dekang_wu
Problem Description:
I setup a LISP demonstration for VM vMotion across DCI. But I has some problems: Same platform (IOS) ping each other reachable, but difference platform ping each other UNREACHABLE. (Diagram and details as attachment.)
For example:
  1. AET12C-OCW03(N7K,NXOS, 50.50.50.50) --> NEC12C-OCW03(N7K,NXOS, 60.60.60.60) Reachable
  2. WAN-SW(C3560,IOS XE, 20.20.20.20 or 20.0.0.11) --> NEC12C-CSW01(C3560,IOS XE, 80.80.80.80) Reachable
  3. Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) --> Remote-Site2 (C1941,IOS, 40.40.40.40) Reachable
  4. Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) --> AET12C-OCW03(N7K,NXOS, 50.50.50.50) Unreachable
  5. NEC12C-CSW01(C3560,IOS XE, 80.80.80.80)--> AET12C-OCW03(N7K,NXOS, 50.50.50.50) Unreachable
  6. Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) -->NEC12C-CSW01(C3560,IOS XE, 80.80.80.80) Unreachable
Topology
Hardware & Software
Hostname
Hardware
Software
Configuration
4 vdc:
AET12C-OCW03
AET12C-OCW06
NEC12C-OCW03
NEC12C-OCW06
N7010+SUP1+M132XP
NXOS 6.2(2)
EPLD: 186.008
4 vdc:
AET12C-OCW01
AET12C-OCW02
NEC12C-OCW01
NEC12C-OCW02
N7010+SUP1+M108X2+M148GT
NXOS 6.2(16)
WAN-SW
WS-C3650-8X24PD-S
IOS XE 16.3.3
AET12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.6.3
NEC12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.3.3
Remote-Site1
CISCO1941/K9
IOS 15.4(3)M4
Remote-Site2
CISCO1941/K9
IOS 15.4(3)M4
Test
CISCO1941/K9
IOS 15.6(3)M4
Show & Debug
Problem 1:
  1. Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) --> AET12C-OCW03(N7K,NXOS, 50.50.50.50) Unreachable
  2. NEC12C-CSW01(C3560,IOS XE, 80.80.80.80) --> AET12C-OCW03(N7K,NXOS, 50.50.50.50) Unreachable
Remote-site1 hasn’t map-cache of 50.50.50.50.
Above is the debug log of AET12C-OCW03(N7K,NXOS, 50.50.50.50). It seems received “Map-request” and build a “Map-reply”. But Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) didn’t receive the Map-reply.
If I add a static map-cache 50.50.50.50 at Remote-Site1, the Ping to AET12C-OCW03 is reachable.
Why Remote-Site1 can’t receive the map-reply?
Problem 2:
  1. Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) --> NEC12C-CSW01(C3560,IOS XE, 80.80.80.80) Unreachable
 Issue ping test on a PC(30.0.0.11) of Remote-site1
Show ip lisp map-cache on Remote-Site1 router(C1941,IOS, 30.30.30.30)
Issue ping test on NEC12C-CSW01(C3560,IOS XE, 80.80.80.80) and show ip lisp map-cache.
They all have completed map-cache, but can’t ping reachable each other.
I turn on DEBUG on Remote-Site1 (C1941,IOS, 30.30.30.30 or 30.0.0.11) and NEC12C-CSW01(C3560,IOS XE, 80.80.80.80).
Issue a ping from 30.0.0.11 --> 80.80.80.80.
I found Remote-Site1 received ICMP-request, but other site NEC12C-CSW01 hasn’t any debug log
Issue a ping from 80.80.80.80 -à. 30.0.0.11. They all haven’t any debug log.
Why??
6 Replies 6
Victor Acevedo
Hello Dekang_Wu,
Before we continue troubleshooting, we should address a few issues. It seems that you have unsupported software and hardware in your setup. With unsupported versions and modules, unexpected behaviors will occur.
Hostname
Hardware
Software
Supported SW/HW
4 vdc:
AET12C-OCW03
AET12C-OCW06
NEC12C-OCW03
NEC12C-OCW06
N7010+SUP1+M132XP
NXOS 6.2(2)
EPLD: 186.008
 On N7k's only M132 linecards are supported and only on 6.2.(12) and above
4 vdc:
AET12C-OCW01
AET12C-OCW02
NEC12C-OCW01
NEC12C-OCW02
NXOS 6.2(16)
WAN-SW
WS-C3650-8X24PD-S
IOS XE 16.3.3
Should be ok
AET12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.6.3
Should be ok
NEC12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.3.3
Should be ok
Remote-Site1
CISCO1941/K9
IOS 15.4(3)M4
 On the ISR G2 platforms, LISP is only supported on 15.5(2) and above
Remote-Site2
CISCO1941/K9
IOS 15.4(3)M4
Test
CISCO1941/K9
IOS 15.6(3)M4
Please make the needed upgrades in software and hardware in order to have LISP function properly. This information and more is documented in the following doc:
http://lisp.cisco.com/lisp_hwsw.html#HW
Vic
Hello Victor,
Thank you for your comment. That's true if it with unsupported versions and modules, unexpected behaviors will occur. I upgraded new firmware of G2 router and N7K, details as following.
Hostname
Hardware
Software
4 vdc:
AET12C-OCW03
AET12C-OCW06
NEC12C-OCW03
NEC12C-OCW06
N7010+SUP1+M132XP
NXOS 6.2(2)
EPLD: 186.008
Upgraded to
NXOS 6.2(20)
EPLD: 186.010
4 vdc:
AET12C-OCW01
AET12C-OCW02
NEC12C-OCW01
NEC12C-OCW02
NXOS 6.2(16)
Upgraded to
NXOS 6.2(20)
WAN-SW
WS-C3650-8X24PD-S
IOS XE 16.3.3
AET12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.6.3
NEC12C-CSW01
WS-C3650-8X24PD-S
IOS XE 16.3.3
Remote-Site1
CISCO1941/K9
IOS 15.4(3)M4
Upgraded to
IOS 15.6(3)M4
Remote-Site2
CISCO1941/K9
IOS 15.4(3)M4
Upgraded to
IOS 15.6(3)M4
Test
CISCO1941/K9
IOS 15.6(3)M4
I have only one M132XP module in N7K-1,  so I use this N7K-1 to create 4 vdc(AET12C-OCW03 ; AET12C-OCW06; NEC12C-OCW03; NEC12C-OCW06) to art xTR role.
After software upgraded, the problems remains unresolved.
Hello Dekang_Wu,
Thank you for taking this very important step. And lets see what is going on with your setup.
Let's tackle problem 1 first. I can see that the your MSMR may be missing the 50.50.50.50/32 entry. In the output you shared, we can only see the /24's (maybe ok if we are not using LISP for mobility). In order to confirm this, can you please share the outputs of "show lisp site name DC1 detail" from the MSMR. This should include more specific EID"s we have received from DC1.
Also, from DC1 (AETI2C-OCW03), can you please share the following outputs:
  • show ip lisp database
  • show lisp dynamic-eid summary
  • show run  <<< I do not see your configs attached here even though they are referenced in the LISP issue docx file
From Remote Branch 1 can you just share your "show run".
Thx,
Vic
Dear Victor,
Thank you for help. please find the log and configuration as attachment. thanks.
Hey Dekang_Wu,
Thank you for sharing these configuration files. Are these the latest configuration files? I see that some of your N7k's are still showing running 6.2.(2) code instead of the code that supports LISP(6.2.12 and above).
Also, I do see that your WAN-SW which is your MSMR has "encapsulation vxlan" for your LISP configs. Can we remove this and test again?
Finally, can you send me a "show ip route" from the remote1 router?
Vic
Dear Victor,
I'm very sorry for late reply.The latest configuration as attachment, the previously configuration attached was captured before the NXOS upgrade, but It should haven't any change after upgrade.
This "encapsulation vxlan" command is always been my confusion, there are few reference. I tried to remove it but no works.
IOS router has this command , but unfortunately it's no works on my C1900 platform.
