04-23-2024 06:40 AM
Hi All,
Can any one confirm that on a N7K-F312FQ-25 SUB2E is IEEE 802.1AE MACsec not supported?
thanks with any pointers.
with kind regards
piotr
Solved! Go to Solution.
04-23-2024 11:53 AM
what nexus os code running what sup models (may be some line cards may not suppot_
as per i know F3 module spported - Feature History for Cisco TrustSec MACSec
04-23-2024 11:53 AM
04-24-2024 05:05 AM
thank you for the information so far.
my module info:
Mod Ports Module-Type Model Status
1 0 Supervisor Module-2 N7K-SUP2E active *
2 0 Supervisor Module-2 N7K-SUP2E ha-standby
4 12 10/40 Gbps Ethernet Module N7K-F312FQ-25 ok
running version:
BIOS: version 2.12.0
kickstart: version 8.4(6a)
system: version 8.4(6a)
it is important for me to have hardware macsec capable ports like on a N7K-F348XP-25 port 41-48 are macsec ports.
I just can’t find definitive answer like for the N7K-F348XP-25.
04-24-2024 05:25 AM
I have just foud it. Thank you for help BB:
04-24-2024 05:32 AM
this looks better, last line is regarding the macsec support = NO
