MACSec not supported on N7K-F312FQ-25?
piotrn001
Hi All,
Can any one confirm that on a N7K-F312FQ-25 SUB2E is IEEE 802.1AE MACsec not supported?
thanks with any pointers.
with kind regards
piotr
balaji.bandi
what nexus os code running  what sup models (may be some line cards may not suppot_
as per i know F3 module spported - Feature History for Cisco TrustSec MACSec
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/security/config/cisco_nexus7000_security_config_guide_8x/configuring_cisco_trustsec_macsec.html
BB
balaji.bandi
BB
thank you for the information so far.
my module info:
Mod Ports Module-Type Model Status
1 0 Supervisor Module-2 N7K-SUP2E active *
2 0 Supervisor Module-2 N7K-SUP2E ha-standby
4 12 10/40 Gbps Ethernet Module N7K-F312FQ-25 ok
running version:
BIOS: version 2.12.0
kickstart: version 8.4(6a)
system: version 8.4(6a)
it is important for me to have hardware macsec capable ports like on a N7K-F348XP-25 port 41-48 are macsec ports.
I just can’t find definitive answer like for the N7K-F348XP-25.
I have just foud it. Thank you for help BB:
piotrn001
this looks better, last line is regarding the macsec support = NO
