12-13-2018 05:01 PM - edited 03-01-2019 08:50 AM
Dears,
How can I configure the IPv6 MLS SNOOPING on the Nexus 93180YC-EX? I'm working on a Dell Vxrail solution. I need to make the following settings:
For the Management VLAN, you also need to enable IPv4 IGMP snooping, IPv6 MLD snooping, and the snooping queriers. Enter the following commands:
For the VSAN VLANs, you need to enable IPv4 IGMP snooping and the snooping querier. Enter the following commands for those VLANs:
I typed these commands but it does not working! I guess!
switch(config)# interface ethernet 2/1
switch(config-if)# ipv6 mld version 2
switch(config-if)# ipv6 mld join-group FFFE::1
I do not see anything by the command
show ipv6 mld interface
Questions:
1) Is any license required?
2) Where is my mistake?
Software
BIOS: version 07.61
NXOS: version 7.0(3)I7(3)
BIOS compile time: 04/06/2017
NXOS image file is: bootflash:///nxos.7.0.3.I7.3.bin
NXOS compile time: 2/12/2018 13:00:00 [02/12/2018 19:13:48]
Hardware
cisco Nexus9000 93180YC-EX chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 24633488 kB of memory.
Processor Board ID FDO223205VA
Please, what can i do?
Regards,.
Marcio - HxBrasil
12-20-2018 05:41 AM
Marcio,
Unfortunately, there is currently no support for MLD Snooping across any NX-OS platform. However, I've seen many customers deploy Dell's VxRail solution by simply allowing the L2 IPv6 traffic to flood on the VLAN without any issues.
Hope that helps.
01-23-2019 07:38 AM
Thank you my friend for your reply!
But how can i enable L6 IPV6 on the VLANS? It´s is very subjective to NXOS
God Luck,
Marcio
