N5K-N2K design :: comparison straight through vs Activie Active topology
Farhad Ahmed
Hi ,
Can anyone provide comparison on N5K-N2K  straight through vs Activie Active topology  . Besides need answer on below
- Can we send active active traffic using Straight Through Topology with out using VPC at server end.
Thanks in advance .
Farhad
Sunil Kumar NR
Hi Farhad,
Please look into below links where you will find more details about straight-through, active-active and enhanced vPC topologies.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_enhanced_vpc.html
I don't think you'd be able to send active-active traffic just using straight-through topology. You can use vPCs and bind the 2 straight-through fexs spread across 2 leaf switches for active-active traffic though.
Please find the below link as well where supported topologies between Nexus and fex devices are captured.
http://www.cisco.com/c/en/us/support/docs/switches/nexus-2000-series-fabric-extenders/200363-Nexus-2000-Fabric-Extenders-Supported-Un.html
Sunil.
Sunil Kumar NR
Hi Farhad,
Sunil.
