N9K-C9372PX / N9K-C9372TX supports break-out mode for UPLINK interfaces ?
wim.juste
Dear All,
Anyone knows whether Nexus 9372 (PX / TX) support break-out mode for the 4x 40GE Uplink interfaces?
Allowing to uplink the switch using 10GE interface capacity, rather then the full 40GE interface?
As stated in the documentation for 9300's modules M6PQ and M12PQ, this is not the case.
But what about Nexus 9372 (PX/TX) ?
Thank you,
Kind regards,
Wim
nezhang
you can check my case ID SR 632711259
all nexus 9300 dose not support breakout
nezhang
2017-12-04
This reply / solution should be updated to note that some Nexus 9300 models now support breakout when running a minimum software version.  See the following page for reference:
Cisco 40-Gigabit Ethernet Transceiver Modules Compatibility Matrix
I hope this is true, however am unable to replicate it. Am I missing something obvious here?
switch# sh version
Cisco Nexus Operating System (NX-OS) Software
Software
BIOS: version 07.65
NXOS: version 9.2(3)
BIOS compile time: 09/04/2018
NXOS image file is: bootflash:///nxos.9.2.3.bin
NXOS compile time: 2/17/2019 5:00:00 [02/17/2019 15:07:27]
Hardware
cisco Nexus9000 C93120TX Chassis
Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16400296 kB of memory.
Processor Board ID SAL1947XXX
Device name: switch
bootflash: 51496280 kB
switch# sh int cap | i i breakout
Breakout capable: no
switch# sh module
Mod Ports Module-Type Model Status
1 102 96x1/10G-T 6x40G Ethernet Module N9K-C93120TX active *
Mod Sw Hw Slot
1 9.2(3) 1.0 NA
Mod MAC-Address(es) Serial-Num
1 cc-46-d6-xx-xx-60 to cc-46-d6-xx-xx-df SAL1947THPU
Mod Online Diag Status
1 Pass
switch(config)# interface breakout module 1
Error:The module in slot(1) is not online or does not support breakout config
