Nexus 3548 temperature alarm
jianghao jiang
Hi all,
    My name is Harry from China shanghai and  I have a trouble in Cisco Nexus 3548 switch  the system reload at 2 min after shutdown .
    How can i do it please help me.
System info
N3548# sh inventory
NAME: "Chassis", DESCR: "Nexus 3548 Chassis"
PID: N3K-C3548P-10G    , VID: V00 , SN: FOC1625R004
NAME: "Module 1", DESCR: "48x10GE Supervisor"
PID: N3K-C3548P-10G    , VID: V00 , SN: FOC16245CPU
NAME: "Fan 1", DESCR: "Chassis fan module"
PID: NXA-FAN-30CFM-F   , VID: N/A , SN: N/A
NAME: "Fan 2", DESCR: "Chassis fan module"
NAME: "Fan 3", DESCR: "Chassis fan module"
NAME: "Fan 4", DESCR: "Chassis fan module"
NAME: "Power supply 1", DESCR: "AC power supply"
PID: N2200-PAC-400W    , VID: V04 , SN: DTN1707P1VV
NAME: "Power supply 2", DESCR: "AC power supply"
PID: N2200-PAC-400W    , VID: V04 , SN: DTN1707P1VS
N3548#
N3548#
N3548# sh ser
% Invalid command at '^' marker.
N3548# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.9.0
  loader:    version N/A
  kickstart: version 6.0(2)A4(3)
  system:    version 6.0(2)A4(3)
  Power Sequencer Firmware:
             Module 1: version v2.1
  BIOS compile time:       10/13/2012
  kickstart image file is: bootflash:///n3500-uk9-kickstart.6.0.2.A4.3.bin
  kickstart compile time:  11/21/2014 9:00:00 [11/21/2014 19:29:20]
  system image file is:    bootflash:///n3500-uk9.6.0.2.A4.3.bin
  system compile time:     11/21/2014 9:00:00 [11/21/2014 21:09:06]
Hardware
  cisco Nexus 3548 Chassis ("48x10GE Supervisor")
  Intel(R) Pentium(R) CPU  @ 1.50GHz
 with 3805876 kB of memory.
  Processor Board ID FOC16245CPU
  Device name: N3548
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 4 second(s)
Last reset at 30232 usecs after  Fri Dec 19 21:29:56 2014
  Reason: Power down due to temperature sensor policy trigger
  System version: 6.0(2)A4(3)
  Service:
plugin
  Core Plugin, Ethernet Plugin
--More--2014 Dec 19 21:28:11 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 105 seconds due to major temperature alarm
2014 Dec 19 21:28:16 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 100 seconds due to major temperature alarm
2014 Dec 19 21:28:21 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 95 seconds due to major temperature alarm
2014 Dec 19 21:28:26 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 90 seconds due to major temperature alarm
2014 Dec 19 21:28:31 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 85 seconds due to major temperature alarm
2014 Dec 19 21:28:36 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 80 seconds due to major temperature alarm
2014 Dec 19 21:28:41 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 75 seconds due to major temperature alarm
2014 Dec 19 21:28:46 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 70 seconds due to major temperature alarm
2014 Dec 19 21:28:51 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 65 seconds due to major temperature alarm
2014 Dec 19 21:28:56 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 60 seconds due to major temperature alarm
2014 Dec 19 21:29:01 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 55 seconds due to major temperature alarm
2014 Dec 19 21:29:06 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 50 seconds due to major temperature alarm
2014 Dec 19 21:29:11 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 45 seconds due to major temperature alarm
2014 Dec 19 21:29:16 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 40 seconds due to major temperature alarm
2014 Dec 19 21:29:21 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 35 seconds due to major temperature alarm
2014 Dec 19 21:29:26 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 30 seconds due to major temperature alarm
2014 Dec 19 21:29:31 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 25 seconds due to major temperature alarm
2014 Dec 19 21:29:36 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 20 seconds due to major temperature alarm
2014 Dec 19 21:29:41 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 15 seconds due to major temperature alarm
2014 Dec 19 21:29:46 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 10 seconds due to major temperature alarm
2014 Dec 19 21:29:51 N3548 %$ VDC-1 %$ %PFMA-0-SYS_SHUTDOWN: System shutdown in 5 seconds due to major temperature alarm
NBCMECN
Hi Jiang
Goo days
so you find what a problem and could solve or not?
Regs
Sameer
