Cisco Intersight Critical Alert for Cluster Disk Capacity 76%
We have an HyperFlex systems with 5 nodes HXAF240C-M5SX and 85TB of total storage with 59.5TB already in use (Data Replication Factor 3)In UCS Manager and Cisco HyperFlex Connect, all appears healthy, however we have a Critical Alert in Cisco Intersight, in the Hyperflex cluster health summary: "Cluster disk capacity will reach 76% in 41 days", and I need to confirm if it's a real critical alert and why?
Thanks in advance,
Omar De Souza.
Yes, that's Intersight's way of of getting your attention, and getting you to address a potentially large problem, before it actually becomes a large problem
Kirk...
Kirk J
Intersight is analyzing your current usage trends, and expects you to hit 76% utilization in the near future.
As all the converged nodes contribute to usable space, Hyperflex has to avoid scenarios where you can no longer take a node outage , such as what would be required for upgrades, etc.
Also, when the usage gets that high, you also see more aggressive cpu/i/o for the cleaner processes that are trying to remove the deleted data, still pending permanent deletion.
https://www.cisco.com/c/en/us/products/collateral/hyperconverged-infrastructure/hyperflex-hx-series/white-paper-c11-744026.html
https://www.cisco.com/c/en/us/products/collateral/hyperconverged-infrastructure/hyperflex-hx-series/white-paper-c11-744026.html#Spaceusageseffectonperformance
Kirk...
Hi Kirk,
Thanks for your answer.
I understand the configuration, I would like to know why for Cisco HyperFlex Connect my system is "Healthy" (69%) and it only will show a "warning" when the capacity is 76% and why for Cisco Intersight there is a Critical Alert in red when I'm in 69%, that is a “critical alert” telling me that “in the future” the system will reach a “warning” percentage of 76%.
Omar De Souza.
Kirk...
