Nexus 5000 loader problem
Hi all,
I have recently powered on my new Nexus 5596UP.  Haven't done much config, but restartet it twice.  The third time, it won't start up.
It comes to the loader> prompt.
Trying to do dir bootflash: og dir usb1: says Error 30: invaldig argument.  It looks like it doesn't know about the bootflash or usb.
I tried setting IP and GW, and issue boot tftp://ip-address-to-tftp-server/kickstart-filname-here, but it doesn't start downloading the kickstart bin file.
Any ideas what causes this problem?
Br
Geir
Prashanth Krishnappa
I checked in my lab Nexus 5500 which does not have card in its USB drive and see the same error. Can you try doing just a "dir"? and boot?
loader> dir
bootflash:
  vlan.dat
  lost+found
  test
  n5000-uk9.5.1.3.N1.1.bin
  mts.log
  vdc_2
  vdc_3
  vdc_4
  n5000-uk9-kickstart.5.0.3.N2.2a.bin
  n5000-uk9.5.0.3.N2.1.bin
  s382_1
  fcoe.pcap
  24.10.5548-UP-running-config
  k382
  n5000-uk9.5.1.3.N1.1a.bin
  dplug.bin
  aaa_cnv.log
  assoc_mgr_cnv.log
  n5000-uk9-kickstart.5.1.3.N1.1.bin
  20120111-235241_1326298137_0x101_snmpd_log.4581.tar.gz
  core
  stp.log.1
  fcoe_mgr_cnv.log
  vfc_cnv.log
  convert_pfm1.log
  dplug1
  dplug
  cfg-backup
  s382
  k382u
  afm_cl.log
  afm_cl_sp.log
  fwm.out
  dcnm-172.18.121.103-ckpnt.cfg
  s382u
  fwm_pre_issu_dump.txt
  n5000-uk9-kickstart.5.1.3.N1.1a.bin
  nuova-or-dplug-mzg.5.1.3.N1.1a.388.bin
  dplug-fh-patch
  1330349384_0x101_port-profile_log.3033.tar.gz
  flogi_cnv.log
loader> dir bootflash:
Error 30: Invalid argument. Please do "help " to get the usage
loader> dir usb1:
loader> boot bootflash:n5000-uk9-kickstart.5.1.3.N1.1a.bin
Booting kickstart image: bootflash:n5000-uk9-kickstart.5.1.3.N1.1a.bin....
.................................Image verification OK
loader> dir
slot0:
  lost+found
loader>boot
loader> dir usb1:
Br
Geir
Your switch sees this
loader> dir
slot0: <<<-----
My lab switches see this
loader> dir
bootflash: <<---
I do not even see a slot0: Looks like you might need a replacement.
Funny this one.  I opened a case with our vendor.  They came onsite, and did the same commands that I had done earlier.
I had also tried power it off/on in different ways.  When my vendor did the same, it startet with normal boot sequence and load software and config. Now it runs ok.  I have even rebooted it a couple of times after this, and now it seems to be working fine.  Expensive troubleshooting from my vendor there :-(
Geir
