Nexus 5010 - SFP Validation failed with 1000BASE-T SFP
we have a Nexus 5010 with some SFP 1000BASE-T that we are unable to configure, when we try to set speed 1000 on the interface that contains the SFP we have the error message:
"Configuration does not match the port capability"
nexus1# sh int e1/20 capabilities
Ethernet1/20
  Model:                 N5K-C5010P-BF-SUP
  Type (SFP capable):    1000base-T
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off/on),tx-(off/on)
  Rate mode:             none
  QOS scheduling:        rx-(6q1t),tx-(1p6q0t)
  CoS rewrite:           no
  ToS rewrite:           no
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  MDIX:                  no
  Pvlan Trunk capable:   yes
  TDR capable:           no
  Port mode:             Switched
  FEX Fabric:            yes
  POE capable:           no
nexus1# sh int e1/20 transceiver
Ethernet1/20
    transceiver is present
    type is 1000base-T
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4B
    revision is 2
    serial number is AGM160321S5
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
To configure the sfp we go in conf then
nexus1(config-if)# speed 1000
ERROR: Ethernet1/20: Configuration does not match the port capability.
Lucien Avramov
Level 10
Level 10
You need to use any of the first 8 ports for 1G on 5010.
Port 1/20 does not support 1GE speed on this platform.
Lucien Avramov
Level 10
Level 10
to give further infos:
nexus1(config)# exit
nexus1# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2011, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.3.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(1)
  system:    version 5.0(3)N2(1)
  power-seq: Module 1: version v1.2
  BIOS compile time:       09/08/09
  kickstart image file is: bootflash:/n5000-uk9-kickstart.5.0.3.N2.1.bin
  kickstart compile time:  6/13/2011 6:00:00 [06/13/2011 15:43:33]
  system image file is:    bootflash:/n5000-uk9.5.0.3.N2.1.bin
  system compile time:     6/13/2011 6:00:00 [06/13/2011 17:33:42]
Hardware
  cisco Nexus5010 Chassis ("20x10GE/Supervisor")
  Intel(R) Celeron(R) M CPU    with 2073408 kB of memory.
  Processor Board ID FOC16021K9L
  Device name: nexus1
  bootflash:    1003520 kB
Kernel uptime is 0 day(s), 0 hour(s), 18 minute(s), 52 second(s)
Last reset
  Reason: Unknown
  System version: 5.0(3)N2(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin, Fc Plugin
blasmoreno
So just to confirm I can use a copper 1000BASE-T SFP in a Nexus 5010 as long as its in the first 8 ports?  I am running on my Nexus:
kickstart: version 5.2(1)N1(7)
system:    version 5.2(1)N1(7)
SW1SAN-SW001# sh interface ethernet 1/6 capab
Ethernet1/6
  Type (SFP capable):    10Gbase-(unknown)
  Speed:                 1000,10000
  Duplex:                full
