My question is concerning the software-imposed distance limitations for Nexus-to-Fex connections.
With a Nexus 5010 running 4.2 (1) N1 (1) code, I believe there is a software limitation on the distance the FEX can be located from the Nexus. I have two questions concerning this:
- Is there any log data, or a cli command, to verify that the fex connection has exceeded that distance?
- What symptoms are produced when the fex is too far from the Nexus (ie, does the link come up but the image not load?)
I would like to determine that the reason I have a FEX, located in a second data centre, that is not coming up is actually related to the distance from the FEX to the Nexus and not related to some other problem.
Thanks for any suggestions/info offerred.
Simon
