Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 5548UP vPC PIM-SSM
Does anyone configure pim-ssm in vPC domain ? I am looking for some config/experience before I start.
I know that PIM-SSM in vPC is only supported  with FabricPath licencse which I allready got it.
Regs
Martin
Alain Moretti
An explanation to this problem, and a simple workaround, without Fabric path : http://bit.ly/1iNxr2H
Alain Moretti
I've the same problem, the link doesn't work, any one can help me about the fabric path
Best regards,
Hi lilyzima1
direct link to the post : http://blog.alainmoretti.com/pim-ssm-through-nexus-vpc/
