Nexus 7000 Switch Fabric Redundancy with Fab-2 ?
dumlutimuralp
Hi all,
I know that N7K did not have N+1 Switch Fabric redundancy. It is required to have all five SF modules to provide full throughput. Does this change with FAB-2 modules ? I mean with new modules, does N7K have N+1 SF redundancy ?
Thanks in advance.
Dumlu
Jerry Ye
The N+1 fabric redundancy will depend on the type of module.
If you are using M132 (80G) per slot and you have 3x FAB-1 (46G each), it will provide N+1.
The same story applies to FAB-2. If you are using the F1 series, and have 4x FAB-2, you have N+1. Of course, if you are using F2 series linecard and have all FAB-2 populated, you don't have N+1 because F2 is 480G and all 5 FAB-2 will give you 550G.
HTH,
jerry
Thank you. I thought Fab-2 modules provides 220G per slot but noticed that it gives 110 Gbps per slot.
cheers.
Dumlu
