NEXUS 7000 xcvrInval
erickflamenco
I have some Nexus 7000 with FET-10G with xcvrInval status
Eth7/33          N5k-S1-3T-1/3   xcvrInval trunk     auto    auto    Fabric Exte
and some other FET-10G with notconn status
Eth7/8           FEX-101         notconnec 1         auto    auto    Fabric Exte
If I inter exchange the position of both FET-10G the status port doesn´t change
FET-10G from 7/8 to 7/33
FET-10G from 7/33 to 7/8
7/33 holds xcvrInval status
7/8 holds notconnec status
I have reconfigured from default interface with same results
Next you´ll find the same serial number in deferent port, the diference is the current
when is xcvrInva or when is notconnec
What can I do to get FET10G in e7/33 validated?
sh interface e7/33   transceiver details
Ethernet7/33
      transceiver is present
      type is Fabric Extender Transceiver
      name is CISCO-FINISAR
      part number is FTLX8570D3BCL-C2
      revision is A
      serial number is FNS17201TE5
      nominal bitrate is 10300 MBit/sec
      Link length supported for 62.5/125um fiber is 10 m
      Link length supported for 50/125um OM3 fiber is 100 m
      cisco id is --
      cisco extended id number is 4
      cisco part number is 10-2566-02
      cisco product id is FET-10G
      cisco vendor id is V02
      number of lanes 1
             SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
    Temperature   19.30 C        75.00 C      5.00 C     70.00 C       10.00 C
[7m--More-- [m
    Voltage        3.31 V         3.63 V      2.97 V      3.46 V        3.13 V
    Current        0.06 mA  --     11.80 mA     4.00 mA    10.80 mA       5.00 mA
    Tx Power          N/A        22.69 dBm    8.69 dBm     18.69 dBm     12.69 dBm
    Rx Power          N/A        22.99 dBm    6.09 dBm     18.99 dBm     10.09 dBm
    Transmit Fault Count = 0
    Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
now in slot 7/8
Ethernet7/8
      revision is A
      cisco id is --
      number of lanes 1
    Temperature   23.17 C        75.00 C      5.00 C     70.00 C       10.00 C
[7m--More-- [m
    Voltage        3.30 V         3.63 V      2.97 V      3.46 V        3.13 V
    Current        7.50 mA       11.80 mA     4.00 mA    10.80 mA       5.00 mA
    Tx Power      17.65 dBm      22.69 dBm    8.69 dBm     18.69 dBm     12.69 dBm
    Rx Power     -12.21 dBm --   22.99 dBm    6.09 dBm     18.99 dBm     10.09 dBm
NX7K-1-VDC-3T-S1-L2FP# sh int e7/33
Ethernet7/33 is down (Transceiver validation failed)
admin state is up, Dedicated Interface
  Belongs to Po51
  Hardware: 1000/10000 Ethernet, address: 8478.ac23.6cec (bia 8478.ac23.6cec)
  Description: N5k-S1-3T-1/3
  MTU bytes (CoS values):  MTU  1500(0-2,4-7) bytes  MTU  2112(3) bytes
  BW 10000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, medium is broadcast
  Port mode is trunk
auto-speed  auto-duplex,, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped never
  Last clearing of "show interface" counters 07:22:09
  0 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 0 bits/sec, 0 packets/sec
    30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 0 bits/sec, 0 packets/sec
    300 seconds output rate 0 bits/sec, 0 packets/sec
  RX
    88 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC/FCS  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
Ethernet7/8 is down (Link not connected)
  Belongs to Po101
  Hardware: 1000/10000 Ethernet, address: 8478.ac23.6cd3 (bia 8478.ac23.6cd3)
  Description: FEX-101
  Encapsulation ARPA, medium is p2p
  Port mode is fex-fabric
  EtherType is 0x8100
  Last link flapped 5week(s) 1day(s)
  0 interface resets
[7m--More-- [m
  RX
    10588 unicast packets  0 multicast packets  0 broadcast packets
    4 input packets  0 bytes
    0 Rx pause
  TX
    10588 unicast packets  1 multicast packets  0 broadcast packets
    4 output packets  5688 bytes
    0 jumbo packets
    0 Tx pause
answanso
Hi Erick,
Are you using the FET-10G to connect to a fabric extender? These optics are only usable between a N7K/N5K and the fabric extender. If you have configured "switchport mode fex-fabric" and still receiving the "Transceiver validation failed" error messages this could be a sign of something else possibly hardware related. If you are trying to use the interface for something other than connecting a FEX to the Nexus then that won't work.
Ant
answanso
Hi Erick,
Ant
Hi Ans,
You are rigth, I have defaulted againt the port, now configured with switchport mode FEX, and now the FET-10G is validated
NX7K-1-VDC-3T-S1-L2FP(config-if)#  description FEX-101
NX7K-1-VDC-3T-S1-L2FP(config-if)#   switchport
NX7K-1-VDC-3T-S1-L2FP(config-if)#   switchport mode fex-fabric
NX7K-1-VDC-3T-S1-L2FP(config-if)#   fex associate 101
NX7K-1-VDC-3T-S1-L2FP(config-if)#   medium p2p
NX7K-1-VDC-3T-S1-L2FP(config-if)#   channel-group 101
NX7K-1-VDC-3T-S1-L2FP(config-if)#   no shutdown
NX7K-1-VDC-3T-S1-L2FP(config-if)# sh int e7/33 status
Port             Name            Status    Vlan      Duplex  Speed   Type
Eth7/33          FEX-101         notconnec 1         auto    auto    Fabric Exte
Thanks for your help, and have a nice weekend.
Atte,
EF
