Nexus 7009 N7K-SUP2 Downgrade Issue
Tabish Mirza
Hi Folks,
I  am getting below error when I am trying to downgrade my Nexus 7009  switches from image 6.2.2a to 6.1.4a or 6.1.2. The reason I want to  downgrade them because I have Fabric Extender Cisco Nexus 2248TP which  can not work on Image 6.2.2a as per release note of 6.2 (
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/62_nx-os_release_note.html#wp578652).
CS7009-A# install all kickstart bootflash:///n7000-s2-kickstart-npe.6.1.4a.bin system bootflash:///n7000-s2-dk9-npe.6.1.4a.bin
Installer will perform compatibility check first. Please wait.
Verifying image bootflash:/n7000-s2-kickstart-npe.6.1.4a.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s2-dk9-npe.6.1.4a.bin for boot variable "system".
[#                   ]   0% -- FAIL.
Return code 0x40930077 (Install is not supported between NPE and non-NPE system image).
Pre-upgrade check failed. Return code 0x40930011 (Image verification failed).
CS7009-A# install all kickstart bootflash:///n7000-s2-kickstart-npe.6.1.2.bin system bootflash:///n7000-s2-dk9-npe.6.1.2.bin
Verifying image bootflash:/n7000-s2-kickstart-npe.6.1.2.bin for boot variable "kickstart".
Verifying image bootflash:/n7000-s2-dk9-npe.6.1.2.bin for boot variable "system".
[#                   ]   0% -- FAIL.
Output of show dir bootflash:
ADM-G-CS7009-A# dir bootflash:
          0    Jun 18 16:37:47 2013  20130618_163747_poap_6057_init.log
       1492    Jun 18 23:22:08 2013  20130618_232128_poap_5934_init.log
          0    Oct 21 19:18:37 2013  20131021_191837_poap_5934_init.log
          0    Oct 22 13:41:24 2013  20131022_134124_poap_5934_init.log
          0    Oct 22 13:48:14 2013  20131022_134814_poap_5927_init.log
          0    Oct 22 15:21:19 2013  20131022_152119_poap_5934_init.log
          0    Oct 22 15:27:36 2013  20131022_152736_poap_5927_init.log
          0    Oct 22 15:53:04 2013  20131022_155304_poap_5934_init.log
        281    Jun 18 16:05:41 2013  JAF1712ARAC_11772274.lic
        414    Oct 22 15:00:08 2013  de
  218195278    Jun 18 16:05:30 2013  n7000-s2-dk9-npe.6.1.2.bin
  219109890    Oct 23 18:10:01 2013  n7000-s2-dk9-npe.6.1.4a.bin
  378629008    Oct 22 18:01:01 2013  n7000-s2-dk9-npe.6.2.2a.bin
   36344320    Jun 18 16:04:05 2013  n7000-s2-kickstart-npe.6.1.2.bin
   36353024    Oct 23 18:10:27 2013  n7000-s2-kickstart-npe.6.1.4a.bin
   37094912    Oct 22 18:01:49 2013  n7000-s2-kickstart-npe.6.2.2a.bin
       4096    Jun 18 16:37:14 2013  scripts/
       4096    Jun 18 16:36:38 2013  vdc_2/
       4096    Jun 18 16:36:38 2013  vdc_3/
       4096    Jun 18 16:36:38 2013  vdc_4/
       4096    Jun 18 16:36:38 2013  vdc_5/
        664    Oct 23 12:39:38 2013  vlan.dat
Please help.
Steve Fuller
Level 9
Level 9
I think you've misunderstood the release note. The reference you've provided is for new FEX that are supported from NX-OS 6.2, and not a list of all the FEX supported in this release.
The list of all FEX supported is shown in Table 3 FEX Modules Supported by Cisco Nexus 7000 Series Modules
If this is the only reason you're downgrading the NX-OS version then there should be no need to do so.
Regrds
