nexus 9000 NXAPI REST. How To Clear MAC Table
sebastianpotok
Looking to see if there is a way to clear mac table, mac learned on interface via REST API. According to the docs, we should be able to clear statistics for ports, ipv4 stats but i don't see an option to clear mac table.
developer.cisco.com/docs/cisco-nexus-3000-and-9000-series-nx-api-rest-sdk-user-guide-and-api-reference-release-9-3x/#!managing-the-infrastructure
Sergiu.Daniluk
Hi @sebastianpotok
I do not have a N9K to test this but if you have a testing env, try this:
POST http://<mgmt0_IP>/api/mo/sys.json
"topSystem": { "children": [ { "l2Macs": { "attributes": { "status": "deleted", } } } ] } }
Cheers,
Sergiu
Hi, thanks for your suggestion. I will give it a shot and respond back with my findings.
