Nexus 93180YC-EX 100G interfaces
g.hammond
Hopefully an easy question. I am trying to determine whether the 100G interfaces on a Nexus 93180YC-EX can be channeled. The only documentation I have been able to find on this states the following:
Port-channels are supported on devices with generation 2 (and later) 100G interfaces. (7.0(3)I3(1) and later)
Are the 100G interfaces on this switch generation 1 or 2 and can they be channeled?
Switches we have are running 7.0(3)I5(2).
Manish Gogna
This 'generation' thing is not mentioned explicitly in our docs, however if you check page 25 of the following link it shows the first and second generation modules ( QSPF28 comes under 2nd genration )
https://www.nanog.org/sites/default/files/meetings/NANOG64/1004/20150604_Hankins_Evolution_Of_Ethernet_v1.pdf
The Nexus 9K datasheet shows that6p 40G/100G QSFP28 is used with N9K-C93180YC-EX, so it should be good
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-736651.html
Manish
- Do rate useful posts -
Manish Gogna
Manish
