Nexus 9372PX supports VDC
jay.cruz2739
I would like to check if the Nexus 9372PX supports VDC?
I happen to check out the cli for a nexus 9372PX and it seems vdc commands are available, but tried to look on documentations and it seems Nexus 9000 does not support vdc.
have not tried to explore the vdc commands since the Nexus 9372PX i have access to is on production already.
Thanks in advance.
InayathUlla Sharieff
  • Only one VDC! Thats it.
Inayath
Thank you!
Is there any Nexus 9000 models that supports VDC?
Jay,
No that which I am aware of. N9K are not designed for that hence you cannot create more VDC on the same.
Inayath
***Please donot forget to rate the post if helpfull***
jkilleda
Level 3
Level 3
Hello Jayson,
Cisco Nexus 9000 Series switches currently do not support multiple VDCs. All switch resources are managed in the default VDC
