NX 2224 Etherchannel issues - 2224 limits - Bug or myself
jerome.gomez
Hi all,
does anybody know if there is a kind of limitation to deploy Etherchannel on 2224 FEX (VPC or Not, Mode on or LACP)
In fact i tried to setup a channel on a 2224 and ports came in err disable mode with a reason set to null
When i apply the same config to a 2248 (same fex N°, same ports, same devices at the other end), it works perfectely
thanks for your help
regards
mbinzer
i just looked and there is a known defect:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl68802
please check if that applies to your scenario aswell.
thanks...
Matthias
mbinzer
thanks...
Matthias
it looks like yes. Error message is the same and I'm in impacted releases. I'll try to upgrade on monday and let you know what's the status.
Thanks for your help
thanks Matthias you were right. After upgrade plroblem is solved.
kind regards
thanks for letting us know. :-)
Matthias
