NX7K M and F series mixed chassis best practice?
gwhuang5398
Level 2
Level 2
I have NX7010 chassis' with mixed M and F series line cards. Fucntions to implement include VDC, vPC, VRF, and L3 routing. What are the best practices for mixed chassis? I once saw a Cisco document talking about it but couldn't find it right now.
Thanks in advance
2 Accepted Solutions
sean_evershed
Level 7
Level 7
Did you mean F1 and M1 cards? If so see below
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/VMDC/2.6/vmdcm1f1wp.html
rfalconer.sffcu
Level 3
Level 3
I've found this to be a helpful quick comparison for the line cards:
http://www.cisco.com/en/US/products/ps9402/prod_models_comparison.html#~tab-c,
sean_evershed
Level 7
Level 7
rfalconer.sffcu
Level 3
Level 3
Thanks both.
Understand Layer 3 functions should be performed by M1 ports. But if I use F2e 10G ports to build a trunk between 2 NX7K, then use a SVI to make Layer 3 adjacency across this trunk connection, is it ok?
I can use M1 1G ports to build this trunk too but I would prefer F2e 10G ports if this is ok.
