OTV 'rewrite ingress tag translate' command not working as expected
Tom Teunissen
I hope someone can help me in resolving this OTV issue. I have setup 2 ASR1002-X routers on a WAN connection and they see each other as adjacent server, so that is working. However in the left datacenter we have a different VLAN numbering we can't use in the right datacenter, so we have to rewrite the VLAN tag...
With these configurations, the mac-addresses located on the left datacenter aren't visible on the right OTV router via 'show otv route vlan 200', it feels like I'm overlooking something really small, but I can't find much on the internet.
Please help? :-) Thanks!
LEFT SIDE OTV
otv fragmentation join-interface Port-channel1
otv site-identifier 0001.0001.0001
 description *** provider OTV WAN-side ***
 mtu 9216
 ip address 172.30.40.1 255.255.255.224
 no negotiation auto
interface Port-channel2
 description *** switch OTV LAN-side ***
 no ip address
 no negotiation auto
 service instance 2411 ethernet
  encapsulation dot1q 200
  rewrite ingress tag translate 1-to-1 dot1q 2411 symmetric
  bridge-domain 2411
interface Overlay1
 no ip address
 otv join-interface Port-channel1
 otv vpn-name OTV-VPN
 no otv suppress arp-nd
 otv adjacency-server unicast-only
  bridge-domain 2411
RIGHT SIDE OTV
otv site-identifier 0002.0002.0002
 mtu 9216
 ip address 172.30.36.29 255.255.255.224
 no negotiation auto
 no ip address
 no negotiation auto
  encapsulation dot1q 2411
  bridge-domain 2411
interface Overlay1
 no ip address
  bridge-domain 2411
j.dzidowski
Hello Tom,
Solution of your problem is to correct service instance configuration on Overlay interface on LEFT SIDE OTV.
It should be
interface Overlay1
 no ip address
  bridge-domain 2411
Then it should works.
This is about a logic how frame is flowing through OTV router. For frames coming from RIGHT SIDE OTV they are going through ports PO1 - Overlay interface - PO2 and vice versa. Currently service instance 2411 on Overlay interface is expecting frames with with VLAN 200 (encapsulation dot1q 200) but your frames has tag with VLAN 2411.
j.dzidowski
Hello Tom,
It should be
interface Overlay1
 no ip address
  bridge-domain 2411
Tom Teunissen
Hello Jacek,
That worked like a charm! Thank you very much!!! :-)
If I run into any problems maybe we will hire you or the company you work for :-P
Cheers, Tom
