QoS on a 5548 vPC
Steven Iannetta
I know this is basic, but I am configuring a input service policy to mark bulk traffic into the af11 traffic class via a dscp code 10 polciy on a 5548 with a vPC config below:
interface port-channel7
  switchport access vlan 577
  speed 1000
  service-policy type qos input PGR-mark-af11
  vpc 7
policy-map type qos PGR-mark-af11
    class type qos PGR-bulk-transfer
      set dscp 10
    class type qos class-default
      set qos-group 0
class-map type qos match-any PGR-bulk-transfer
      match access-group name ACL_qos_nbu_boost
IPV4 ACL ACL_qos_nbu_boost
        10 permit tcp any any eq 2049
        20 permit tcp any eq 2049 any
        30 permit tcp any any eq 2051
        40 permit tcp any eq 2051 any
        50 permit tcp any any eq sunrpc
        60 permit tcp any eq sunrpc any
        70 permit tcp any any eq 1556
        80 permit tcp any any eq 13724
Problem is  the traffic is not matching the dscp policy all traffic is best effort.
I aslo tried adding the policy to the individual ethernet interfaces and recived the error "Service policy not allowed on port channel members"
Any help?
6 Replies 6
Andras Dosztal
Level 3
Level 3
Did you configure it on both N5Ks? The two switches in a vPC domain have their own control planes.
You can check it by entering the show vpc consistency-parameters global and the show vpc consistency-parameters interface port-channel 7 command.
yes it is configured on both 5k's.
Andras Dosztal
Level 3
Level 3
Are there any hits on the ACL?
no hits on the acl
You should take a packet capture on the interface to make sure the traffic really passes.
Andras Dosztal
Level 3
Level 3
BTW, QoS on VLAN config guide for Nexus can be found here.
