Remote Span NX-OS
rgonzalch
I need to configure RSPAN between 2 nexus 7000 but i do not understand how to do it on catalyst you configure destination remote vlan
but on nexus that options is not available.
Could anybody show me with an example please?
Best regards.
Thanks in advance!!!
it should help but the code does not work according to what we are being told.. where does it actually work now?
There is current a severity 2 bug on ERSPAN running 5.1.X code.  ERSPAN is broken.  Most likely you are running into a variant of this bug.
CSCto31791
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCto31791
This bug will be fixed in 5.2 code which should be released later this year.
